跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的谷歌 Pixel 6 智能手机的维修与拆解信息。设备型号为 GB7N6 和 G9S9B16。
Fingerprint setting not available
There's no fingerprint option in settings
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Thanks for reaching out. The description is a bit sparse for a single diagnosis, so a few details would help: Was the display recently replaced? Is this a managed/work phone? And which Android build is installed (Settings > About phone)?
For low-risk steps, try restarting the phone, then check for and install any pending system updates. Confirm the expected path: Settings > Security & privacy > Device unlock > Fingerprint & face unlock. You can also test in Safe Mode (press and hold power, then tap and hold Restart) to see if the option appears. If the phone has a work profile or device policy, biometrics may be hidden by an administrator.
If the display was replaced, the under-display sensor may need Google's official Pixel fingerprint calibration workflow, and a non-compatible display can prevent enrollment. Back up your data before any reset, but don't factory reset as a first step—it may not fix a hardware mismatch.
这个答案有帮助吗?
得分 0
添加一条评论
Finger lock option not showing
这个答案有帮助吗?
得分 0
添加一条评论
No finger lock option not showing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raiyan Habib 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 16
过去 30 天: 53
总计 145
