跳转到主内容
加入维修社区 - 创建账户
Apple 專為可望極致效能專業使用者所打造的產品線。目前, MacBook Pro 產品線包括 13、14、15、16、17 英寸機型,並且大致分為原始非一體成型機身、一體成型機身、視網膜螢幕、觸控列、Apple晶片五個世代。
Using Mac with the cover down?
How can I prevent my mac from suspending when the cover is down, I'd like the screen to turn off, but I still want to to be able to connect via ssh, and vnc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Try setting computer sleep to 'never' in energy saver, and connect an external keyboard or mouse. Close the lid, and click mouse or keyboard key to wake unit if it goes to sleep. This should trick the MacBook Pro into "clamshell" mode. You might want to put the unit on a small riser or laptop cool pad, as it is going to get warm...
Check out this article from Apple's Knowledge Base:
http://support.apple.com/kb/HT3131
PS: You shouldn't need an external monitor connected for this to work.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
http://semaja2.net/insomniaxinfo
There is a program called InsomniaX that allows mac laptops to optionally remain awake with the lid shut. This is probably exactly what you want. It is also possible to keep the laptop awake by connecting it to an external screen, keyboard, and mouse.
这个答案有帮助吗?
得分 3
1条评论:
This is what I do to keep mine awake, but I still have it go to sleep after a few hours to save energy.
完成的
添加一条评论
Make sure 'Wake for Ethernet network access' is checked under the Energy Saver preferences.
However, I have never been able to get the MacBook Pro to wake from sleep with the cover closed. I suspect this is done for cooling purposes. I have had some success when a 2nd monitor is connected and turned on. Your mileage may vary.
这个答案有帮助吗?
得分 1
1条评论:
Wake for Ethernet Administrator Access is for something called Wake On LAN, but this won't necessarily work with what Steve wants to do. It certainly won't allow him to ssh or vnc in and have his laptop auto-wake.
完成的
添加一条评论
Use energy saver display sleep also same place check wake for administrator access
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Feinstein 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 4,737
