跳转到主内容
加入维修社区 - 创建账户
三星在 2023 年 2 月 1 日的“Unpacked”发布会上公布了 Galaxy S23 系列产品。同时发布的还有全新的 Galaxy Book3 和 Galaxy Book3 Pro 系列笔记本电脑。
Broken battery pull tab; Safe ways to pry out battery?
​I tried replacing the battery using the iFixit kit (without isopropyl alcohol). Whilst trying to pull out the old battery, the blue pull tab snapped, and I’m a bit hesitant to use a prying tool.
​I’ve closed everything back up for now and will buy a bottle of isopropyl alcohol.
​Could I get some tips on prying out the battery safely without damaging it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @keralite
I find the best way to do this is to apply a line of Isopropyl Alcohol 99%+ along one side edge and the bottom edge of the battery, using an 18G blunt tip dispensing syringe,¹ allow the alcohol a few minutes to soften the adhesive and then gently, use a pry tool to lift the battery up a small bit.
Then apply some more alcohol under the slightly raised edge of the battery, wait for the adhesive to soften a bit and then pry the battery up further and so on until it is completely removed from the case.
Notes:
¹ Examples only. You could always ask your local pharmacist if they have anything suitable that you could use. Just explain what you want to do with it ;-)
Do not attempt to remove the battery all at once. Raise it a bit at a time.
Do not use a metal pry tool as you may easily puncture the battery. Old credit cards or guitar picks can work if you don't have a plastic spudger.
Remember to disconnect the battery cable from the systemboard before commencing the removal procedure and to dispose of the old battery responsibly at a hazardous waste collection point in your location.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abhishek K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 65
总计 146
