跳转到主内容
How to convert the display cables
I have an old, dead iBook G4. Is there any way to use the display as a VGA monitor? I took the display out, but can't make heads or tails of the wires.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You would need to find adapters for the LVDS (video) cable and the inverter cable. This is not currently available on the market so you'd have to cut the LVDS cable connector (logic board end) and solder the wires to a VGA connector. You'd need to know the LVDS cable pins out schematic and the VGA connector corresponding schematic to match them. Not an easy task...
Now there's the power issue. The iBook G4 display use DC power coming from the inverter socket on the logic board. You'd have to find an adequate DC in adapter source to feed the display inverter board. Again good luck with this...
IMHO it's the kind of project I would not go in.
这个答案有帮助吗?
得分 2
添加一条评论
Sure, try this: Here's your hardware solution: http://www.instructables.com/id/Laptop-C...
这个答案有帮助吗?
得分 1
1条评论:
Close, but he uses the motherboard and video card from the old laptop. Everything in mine is dead except for the screen. Is there anyway to just use the display? Thanks
完成的
添加一条评论
添加你的答案
AudVis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 673
