跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
121 个问题 查看全部
classic environment not supported. used. no disks.
I bought a used g4 running os 10.5.8. photoshop 7 just quits after install. indesign, illustrator send same no classic environment error message, but seem to load but graphics import like dirt. 12" g4 discs don't work. where did classic become unsupported and how do I go retro. I may have scanner issues if its the lack classic environment that is causing a problem. All of my software is from approx. 2003. Please help, again. Thank you, Betty
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Could you post your PB 17" model ? Remove the PB battery, the specs should be written in the battery bay.
完成的
添加一条评论
4个答案
已选择的解决方案
The PowerBook Alu will not boot from a OS9 installation disk so, to use the Classic environnement, you must use the original installation disk to install OS9 or transfer a valid OS9 folder already installed from another source. If you know someone who has OS9 installed on his hard drive simply copy it on an external drive (or burn it to a CD/DVD) then transfer it to your hard drive or use the firewire target disk mode to do the transfer.
这个答案有帮助吗?
得分 2
添加一条评论
Classic went out with 10.5. You can load 10.4 and have classic. Go to www.fastmac.com, for older software.
这个答案有帮助吗?
得分 1
2条评论:
ater system 10.4 is installed, you have to then install system 9. it will then run both systems.
完成的
look at this link for the softwaRE YOU NEED
http://fastmac.com/osclassic.php
完成的
添加一条评论
I reinstalled Tiger and get the same warning, Photoshop does load and seems to work. How do I get the original 17" G4 Disks or a valid os 9? Sounds like Apple, ebay. we love macs,etc. are all out due to discontinuation. Any help from you guys? You are great! The geek squad should look on in awww. Thanks again!
这个答案有帮助吗?
得分 0
2条评论:
After you installed Tiger, did you install any System 9 operating software? You have to have both system 10 & 9 installed to use Classic.
完成的
I do not have a valid os 9. I can see the folder in system preferences, but software errors tell me they cant find the folder. I was told to look through tiger disk for an os 9 folder for advanced install not easy instal. photoshop is running and seems to be fine. I couldn't get Sheepshaver to work. I really do love my mac and thanks to you guys I can continue. Thanks again. Betty
完成的
添加一条评论
Sheepshaver is for the Intel. Mine is a PowerPC. i really need the start up discs for this 17" PowerBook G4. If anyone can help with this i'm exhausted and need to decide if I'm sending this used PowerBook back or keeping it and hoping I run across a copy of disc. I have some loading issues I don't know if it is screen or OS problems. Loepard did not want to let Tiger override it. Keep in mind I'm just an average user, but I LOVE my mac.
这个答案有帮助吗?
得分 0
2条评论:
After you installed Tiger, did you install any System 9 operating software? You have to have both system 10 & 9 installed to use Classic. Go to www.fastmac.com, buy System 9 and install it:http://fastmac.com/osclassic.php
完成的
I don't have an os 9. I really need these install discs. fastmac is out of 9.0 would 9.04 work? Any ideas for the original os discs? apple, ebay, and craigslist, ilovemymac, are all out of these discs. There are two discs has apple test.
完成的
添加一条评论
添加你的答案
Betty 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,544
