Internal Speaker does not show on output sound device.
The internal speaker does not show on the output device list only the headphones port is listed. This happens only when I am using the Snow Leopard (tried Lion as well). However, when I boot on Windows 7 through bootcamp, I can see both the internal speakers and the headphones and I can select either of them as the default output sound device. Everything works fine when I am using Windows 7. Nothing is stuck inside the headphone jack. Anyone has experienced this and has a solution?
Are you getting a red light in the audio out port?
由 mayer 完成的
No red light on the audio out port. Does it has an indicator? I didnt notice any on the left side. By the way, I forgot to mentioned that I can hear the chime from the internal speakers when starting up but no sound on OS X.
由 mon 完成的
I had similar issue: no internal speakers available, no input or output devices, no red light out of the port on my Macbook Air El Capitan. I've done NvRam and SMC reset, OS reinstall, tried everything what I found on google, nothing worked. Then I tried one more thing: DEBUG BLUETOOTH, it looks like this resolved my issue :D
Instuctions:
Hold down the Shift and Option keys ('Alt' on some keyboards) and at the same time click on the Bluetooth icon in the menu bar. Once the menu is showing, release the keys. From the Bluetooth menu, choose Debug > Remove All Devices. Reboot your Mac,
由 Wojciech Kulig 完成的
Thank you this helped me greatly
由 tki14752 完成的
i tried this but it did not work for me, what again do i need to do?
由 Harold Bruce 完成的
显示更多的2条评论
