跳转到主内容
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 个问题 查看全部
delaminated upper case on iBook
My son dropped our 12" iBook G4 from chair level and broke the case around the display. The hinge still works, but the case is delaminated. I have an older G3 iBook and was wondering if the case parts from that can be substituted with the broken G4 parts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What are your exact models?
完成的
添加一条评论
1个答案
已选择的解决方案
Yes the iBook G3/G4 displays are similar but they don't use the same cables. The display casing color will not match and the the word G4 will not appear on the the front bezel.
Could you specify the display damage or upload a pict in your question. Often after a drop the panel will separate from the front bezel at the screen base. If the hinges (or other internal parts) are not broken you can open the display and check if the inverter board has moved from his location (it's only glued in place) causing the front gap.
这个答案有帮助吗?
得分 1
1条评论:
That sounds like the problem. I'll try an get a photo tomorrow. Thanks
完成的
添加一条评论
添加你的答案
KWSeal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 636
