跳转到主内容
加入维修社区 - 创建账户
用于汽车的手持式无尘袋吸尘器,由 12V 点烟器供电。
Batteries won't charge.
Batteries in hand held vacuum.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Could be any number of things, Jim, but we don't really have enough to go on to be able to tell you what's wrong with it.
First of all, before we can give you specific advice about, for instance, to replace the batteries, we'd need to know what vacuum you have. Manufacturer and model information is needed.
What have you checked? Does the vacuum have a separate charger? Have you verified that the charger is putting out the correct voltage? Is there some sort of indication that it's charging when you plug it in? Does it work at all on battery, even if just for a moment?
How old is it? Depending on age, it could need the batteries replaced, even if they are rechargeable; most devices use lithium ion batteries nowadays, which have a limited lifetime.
That's about all the generalities I can provide, given that you've given us a total of three words describing your problem and we don't know what vacuum you have. Please edit your question or add a comment with more details and we'll see what we can do to help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim Hort 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 79
