跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30、60 或 80 GB 硬盘 / 黑色或白色塑料面板
iPod won't charge
I bought a used Ipod Classic 5 about two months ago. The seller put a new battery in as well. I have been using it fine for about two months now. Charging via wall and/or computer worked fine. I haven't used it for about two weeks now and the last time I used it I did until the battery was completely drained.
I went to charge it on my wall outlet now and it wouldn't show any signs of life.
I waited a good 2 hours and still nothing happened.
Whenever I tried turning it on, it would just show the apple logo for a brief second and then shut off again.
Something weird to note is that after nothing happening via wall charge I tried charging it on my computer and when I plugged it in I got a windows notification for a USB power surge, telling me to immediately remove the device from USB because it was drawing too much power.
What could be happening? And how do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Replace the battery. The battery the seller replaced it with is probably a low quality cheap one.
这个答案有帮助吗?
得分 0
1条评论:
It looks like you can get the full Fix Kit from iFixit for $19 USD
由完成的 分享
添加一条评论
Try use Firewire if you can, if it shoots into life, which it should as it gives much more power and it lets iPods with even a basically dead battery to turn on, it is probably the battery that is the issue as it may be a low-quallity one.
iPod第五代(视频版)电池更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pazulay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 130
