跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Why is the battery dropping out every couple of minutes?
I just did a screen replacement for my phone and now it turns on and everything works, including taking a charge; however, every couple of minutes (even when plugged in) the phone shuts off and turns back on. I have the AT&T 32gb version of the iPhone 4s. What could cause this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
An inconsistent voltage supply would be the culprit of this, the iPhone 4S requires 3.7 Volts minimum I think, anything less and you might as well take out the battery as not enough power is being delivered to run the iPhone.
Cheap battery replacements will cause this, either ask for a replacement one or for a refund and go to another company. Too low a voltage won't cause any permanent damage as it is literally like taking the battery out of a BlackBerry or HTC whilst it is on.
Hope this helps! (Remember, buy cheap, buy twice!)
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 6
总计 338
