跳转到主内容
加入维修社区 - 创建账户
Meta Quest 3S 混合现实头戴式设备于 2024 年 10 月 15 日发布,比Meta Quest 3 便宜。
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kai Bannon 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 32
过去 30 天: 104
总计 525
