跳转到主内容
型号 A1019 / 10 或 20 GB 硬盘 / Firewire 接口为普通大小
29 个问题 查看全部
Can't restore old iPod 2G Touchwheel
Hello. I bought this pretty rare iPod on eBay. It was in very good cosmetic conditions and worked perfectly except that I could'n sync it with my Macbook Pro 2008 because iTunes didn't recognize it. But it was recognized by Disk Utility as an external hard drive. So I decided to format it and restore in iTunes. There was no problem with formatting it. However iTunes refused to recognize it again. I tried my old Mac Mini G4 with Tiger and iTunes 4 recognized it but there is no opiton to restore it.
Any advice is welcome
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Dmitry Rodin, first thing I would try to do is to place it in diagnostics mode. Follow the instructions from here. See what the diagnostics reveal. Also, check to see if you can access your hard drive in disk mode, just to make sure it is okay. Verify that your firewire port does not show any corrosion etc, and use a known good firewire cable. Of course you do know that in order to finish a restore, you must have a firewire ac adapter. So it is possible that you iPod is stuck in a restore mode and needs to be plugged in to an AC firewire charger. Give it a try an let us know
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dmitry Rodin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 984
