跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
MacBook wont turn on, will display green adapter light/orange charging
Well im hoping you guys can help me out a bit.
my macbook suddenly stopped turning on. It will show green when i put my magsafe in and it charges the battery (orange light) but thats it. No chime no screen response.
Now i have heard of this 'jumping' idea to turn the macbook on directly from the logic board, but i cant quite work out what exact componets i have to touch, does nybody have a picture showing which parts i need to touch on this model to get it to jump?
or are there some things i have missed? i have tried removing battery, unplugging HDD, taking out ram, smc reset etc
i really dont want it to be the logic board :/
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Thats great! thankyou very much
完成的
Did it turn on?
完成的
添加一条评论
11个答案
已选择的解决方案
You are in luck. First what you will have to do is remove the bottom cover of the MacBook. Then you will need to jump these two contacts (top picture, ignore bottom one)
they can be found to the left of the red square on this picture and over the two smaller connectors.
Hope this Helps
这个答案有帮助吗?
得分 1
添加一条评论
i tried but unfortunately it didn't work, pretty sure the logic board is dead. thanks for the help though!
这个答案有帮助吗?
得分 0
1条评论:
Keep in mind, you need to disconnect the keyboard/trackpad ribbon cable before jumping the machine. This model commonly has a sticky power button that will get stuck in the depressed position, and, again, if this is the situation with yours, it's not going to be jump-able until you disconnect the ribbon cable.
完成的
添加一条评论
i did not know that, i shall have another go without the cable in!
thanks
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for this. It worked my mac is running again.
One question tho? Can i insert the keyboard cable again once its running?
这个答案有帮助吗?
得分 0
1条评论:
I got mine running sort of after jumping the power with the ribbon cable disconnected but the display does not come on, no error beeps, no lights except the power adapter.
完成的
添加一条评论
Can anyone tell me how to perform "jumping" on logic board??
Thanks in advance
这个答案有帮助吗?
得分 0
添加一条评论
I need help looking for the jumper for the model mb991LL/A. Can anyone help me out.
这个答案有帮助吗?
得分 0
添加一条评论
look at the picture, you need to short these 2 connections together, a small flat screwdriver would do it, just short out the connector, and that would act like the power button, i guess it tests whether its anything to do with a sticky on off button. my macbook has the same problem, i will try later today!
这个答案有帮助吗?
得分 0
添加一条评论
super, this worked totally for me!now do i have to replace the keyboard or can i try to clean it out somehow?
这个答案有帮助吗?
得分 0
添加一条评论
Hi there,
Sorry I'm not a computer wizard. The jump start process - so I have the battery connector off the board and how will I get into the process of jumping the power?
这个答案有帮助吗?
得分 0
添加一条评论
Thank you so much, it worked for me!!! :)
这个答案有帮助吗?
得分 0
添加一条评论
I have a macbook air it doesnt turn on and yet sometimes it will turn on last a minute or two and then kaput, pretty sure this is the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nate 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 40
总计 99,339
