跳转到主内容
加入维修社区 - 创建账户
The final generation of the Buick Century was released in late 1996 for the 1997 model year.
Rear running lights don't work
I just discovered this evening that my rear lights do not work. My brake lights work when I activate the brakes but when my foot comes off the brake pedal all the back lights are off. I've checked all the fuses. I've checked some relays you can't seem to find any reason why the lights won't function
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @anthonymar76475
Have you checked that the fuse that supplies power for the taillights etc is tight in the fuse holder in the fuse block?
If all the lamps aren't working you need to start checking the 12V from the fuse block fuse¹ to the taillights etc and check how far you get before it's not there. The earth to the tail lamps must be OK because you said that the brake lights work and they connect to the same earth (for each taillight)
Here's an image from the 2002 Buick Century service manual showing the wiring for all the lamps that will help.
Since no lights are working it may be a faulty wire or connection between the fuse and the multiple connection point S408 as this is where it splits to go to the left & right sides and the license plates lights etc
¹ In the 2002 model it is fuse #17 in the instrument panel fuse block
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anthony Marino 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 25
总计 162
