跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Caller name not showing ...
i m using a iphone 4S from sprint. i m using a Gevey card. this phone is not showing any caller name during incoming call or msgs. if i add a contact with +91 then it shows name during incoming but after this i can't reply any msg to that no(like +9198763*****). i can send msg only to without prefix country code.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
i updated the Ios of the iphone to latest firmware 5.1.1 then i changed the Gevey card and program it to new settings acc to their carrier of the phone . This solved the problem of messages and caller name display. i have to do is to save all the number with country prefix . thnx for help
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Service providers in the USA charge extra for caller ID sometimes. If your plan is new, the provider may not be providing caller ID. Call and ask them. Also check this on the use of +91: http://countrycode.org/india
这个答案有帮助吗?
得分 2
3条评论:
my problem is that phone not showing name of the contact . it just show the number if i add the +91 with all the contacts then it shows the contact name during incoming . after adding +91 i cannot reply msg or send a new msg to that number . i have to remove the +91 before sending the msg to any number.
完成的
If your customer is calling from a cell phone, most of the time, in my experience, the name will not show up unless you've programed your phone to show it. Ask if they're using a land line or a cell phone.
完成的
in india if any calling from any line means cell phone or landline or you have saved that number in your phone's address book then your phone display only name not the number even you have saved with country prefix number or not
完成的
添加一条评论
guys have got a sure shot solution for contacts and text message issues for iphone users. please visit the below mentioned link and pls do leave a feedback if it helps u.
http://foneadvisor.blogspot.in/
这个答案有帮助吗?
得分 0
添加一条评论
my iphone does not show caller's identity anymore. Used to before.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SIMRAN 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 29,581
