跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Why does Mac OS X fail to install?
21.5 inch Mid 2011 iMac
In an effort to make the computer brand new, I decided to reinstall Lion. After a quick Google, I erased the hard drive using Disk Utility & restarted in Recovery Mode. I clicked the "Reinstall Mac OS X" option and agreed to the terms, and chose destination to install. It then downloaded a fresh copy of Lion and rebooted to the Mac OS X Installer. Less than a minute into the installation an error pops up:
"Mac OS X could not be installed on you computer.
Mac OS X can't be installed on the disk Macintosh HD, because a recovery system can't be created. Visit http://www.apple.com/support/no-recovery to learn more.
Click Restart to restart you computer and try installing again."
I've retried at least a dozen times with the same results. I know there is a solution out there, but it has evaded me for the past two weeks. Any advice would be appreciated more than you can imagine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Try installing a 10.6 system from your original system installation disk, do the updates to 10.6.8 then install Lion and update again.
这个答案有帮助吗?
得分 3
1条评论:
Check with Disk Utilities to see if you've formatted the drive GUID. Still failing? Do a reformat using the "write zeros" option to map out any bad blocks. This failing, your machine may still be under warranty, get a replacement drive. You are using the original hard drive, correct?
完成的
添加一条评论
I had this same issue. I fixed it by booting into internet recovery mode (Cmd+Option+R) and then opening Terminal from the file menu and using diskutil to delete the highest level Logical Volume Group as shown here Erasing a FileVault 2-encrypted Volume -- Then closed Terminal and opened the Disk Utility GUI tool. Created a new partition. Closed Disk Utility and then ran the install again and it worked!
这个答案有帮助吗?
得分 1
1条评论:
Matt good find!
完成的
添加一条评论
It sounds like your boot table is corrupted. Have you run Disk Utility and reformatted the drive with the Mac OS Extended journaled format?
这个答案有帮助吗?
得分 0
2条评论:
When i try to partition the hard drive, it fails with the error: Couldn't unmount disk.
完成的
You may try a third party format tool to see if it can fix the drive otherwise it sounds like the disk is bad
完成的
添加一条评论
Every time I hold cmd+Option+R it tries to do an internet recover and does the whole process again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bastian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 15,287
