跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
error 13 iPhone 3GS
hi i keep getting error 13 when i try to restore my phone ,can any one help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Is your iPhone jailbroken? A jailbreak can sometimes make it much harder to restore.
完成的
添加一条评论
2个答案
已选择的解决方案
If you tried a different cable and usb port and still have this error try this.
Step 1. close out itunes and disconnect your phone
Step 2. turn your phone completely off
Step 3. relaunch itunes
Step 4. plug in the usb end into your computer, but do not connect your iPhone yet
Step 5: This is the somewhat tricky part....hold down the round circle home button while you plug in your iPhone.
This is should bypass any software currently on the phone that is corrupt and do a fresh install. Of course you probably already know that all information will be lost from your phone - so hopefully you backed up before the crash.
这个答案有帮助吗?
得分 1
添加一条评论
And if Mayer's solution fails, you may need to put it into DFU mode. You can do that by following these steps:
  1. Plug your iPhone into your computer
  2. Turn your iPhone off.
  3. Hold down the home button and power button for exactly 10 seconds.
  4. Release the power button but keep holding the home button.
  5. Hold in the home button for another 10-20 seconds. If you are using Windows, you'll hear the device connection sound. If you are using a Mac, open System Profiler and look at the USB hub. You may need to refresh the tree, but you should see a device labled as "DFU Device" or something along those lines.
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 4,859
