跳转到主内容
Is it worth putting in an SSD boot drive?
Is it worth putting in an SSD boot drive in this machine? My optical drive is shot and I've read that installing an SSD boot drive, then putting the old HDD in the optical drive position (inside a converter bracket) is the way to go. This is a 2006 machine. Any recommendation as to SSD?
Or with this old a machine, would I get just as much speed if I were to install, say, a 7200 rpm drive in place of the original 5400 rpm HDD?
Thanks!
Update
And, I believe I can get an older SSD since my A1150's HD bus is running at 3Gb/s, or am I mistaken about that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I ended up buying a 6G SSD and making it my main drive. I was going to get an adapter for the optical drive bay (since my drive wasn't writing), but I took the drive out, took it apart, sprayed it with air, and now it works perfectly. I know the 6G isn't utilized by my machine, but I can use it in my next mac. In the meantime, I have the fastest A1150 Macbook pro possible for $150 in parts.
完成的
crubeo6611- You've put a comment where only Answers belong.
完成的
I have the same computer what hard drive and memory did you buy?
Dave
mgbrv8@yahoo.com
完成的
添加一条评论
2个答案
已选择的解决方案
This is still a very good machine. A small SSD would work great in it, along with maxing the RAM. If it is the A1150, it will take 2 GB of RAM and run on 10.6.8. The optical bay adapter will work fine for you.
[关联产品丢失或禁用: IF107-078]
这个答案有帮助吗?
得分 3
8条评论:
Thanks!
But, with this old a machine, would I get just as much speed if I were to install, say, a 7200 rpm drive in place of the original 5400 rpm HDD? Or is the SSD still faster?
完成的
The SSD is going to be faster. I'm personally running a 7600 WD Scorpio Black in mine but SSD prices were much higher when I installed it.
完成的
Oh, excellent. OK.
Now, am I correct in that I would replace my boot drive with an SSD drive and run only the OS on it? Or would I install my programs to the SSD Drive as well? Then, use the old drive (in the optical drive adapter for simple storage?
Also, can you recommend an SSD Drive? My machine is maxed out on ram, btw. Thanks.
完成的
Put your operating system and application of the SSD. Use the other drive for storage if you need it. You can now get a 30 GB SSD for $50. http://eshop.macsales.com/shop/internal_...
完成的
完成的
显示更多的3条评论
添加一条评论
As I understand it, there's no need to buy a 6G SSD since your bus can only run at 3G speed. OWC/macsales (who mayer linked to above) has well-reviewed SSDs, thinking of making this same move with my MacbookPro3,1.
I do wish the product description for this made clear that the adapter is allowing you to put a SATA drive in a PATA bay--so your drive in the optical bay will run a little slower than it did in the standard drive spot. Might want to spring for the largest SSD 3G you can afford.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
crubeo66 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 4,640
