跳转到主内容
加入维修社区 - 创建账户
Dishwasher won't start; start button blinks 3 times then turns off
My Whirlpool dishwasher (WDF520PADM7, about 6 years old) will not start. I press the start button, it blinks 3 times, then turns off. I have turned off the circuit breaker for 10 minutes or so, hoping this will reset the machine, but no change. I have run the 123-123-123 diagnostic, all the lights on the control panel light up, but the machine does not run through the testing protocol. I have checked the latch and it seems to be a tight fit. The control lock is not on. Do you have any suggestions as to what else I can try for a DIY fix? Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @anita47514
The door latch might be tight but this doesn't mean that the door latch switch is working OK electrically.
If you have a DMM (digital multimeter) you could disconnect the power to the dishwasher and then access the door latch and use the meter's Ommeter function to check if the latch switch is working OK electrically or not..
Here's a video that shows how to access the latch assembly that will help.
On p.4 of the tech sheet there's a strip diagram showing the door switch circuit.
If the switch is faulty search online for WPW10653840 to find suppliers that suit you best. (examples only)
Secures the dishwasher door in a closed position during operation.图片
产品
Whirlpool Dishwasher Door Latch Assembly - WPW10653840
$25.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Anita 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 157
