跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
123 个问题 查看全部
Unable to Format 30 GIG Quantum Fireball Plus hard drive?
I had a working 30 GIG Quantum Fireball Plus hard drive. I need to install it in a iMac G3 233 to donate. I tried to partition the first 8GIGs at 7.5 to be able install the system correctly. The partitioning failed with a "Resource busy" error. Then tried a standard OSX extended format, same error. Then tried a zero all data and I get:
Disk Erase failed with the error:
Resource busy
I have it in an external Firewire enclosure, hooked to a G5 MacPro 2.0GHz DP. Any ideas?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Richard i"m not sure this will help but the consensus I get reading on this issue you need to unmount the partitions and then proceed with your formating. I know you are a very knowledgeable searcher but am going to include one of many URL's that I found on the subject. Hope this is of some help. Ralph
http://www.macosxhints.com/article.php?s...
http://hints.macworld.com/comment.php?mo...
这个答案有帮助吗?
得分 2
3条评论:
Thanks for the work. + the partitioned volume disappeared when the partition failed. If I unmount now There will be noting to work with.
完成的
Hi, digging around a little more I found a suggestion that by using an earlier version of the OS (i/e 10.3) you could do what you need to do. I don't know if it would work but you can try. Ralph
完成的
Thanks Ralph. You & I seem to be the only ones that kn ow about these old babies. Will have to find a 10.3 machine. Will let you know.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,683
