跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad E15 Gen 2 于 2020 年发布。该机型可选配第 11 代 Intel Core i3/i5/i7 处理器,或 AMD Ryzen 4000 系列 CPU。
Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
  • Power off the device and carefully clean the port using compressed air or a non-metallic tool (such as a wooden or plastic pick).
  • Inspect the port with a flashlight for visible damage or corrosion.
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adrian 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 65
总计 426
