跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 个问题 查看全部
问题已关闭
No log on promt, just blue screen at start up.
My iMac suddely started to show grey bubbles at start up, but Safe start still worked. I then reinstalled the OS and now it just show a blue screen instead of the log on window. I've checked the log files and the system log file says something about ASIC Hang log. Could it be the video card that causes this. I've checked the HD - it looks OK and the computer can be started with Safe start.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you see a blank blue screen, or a blue screen with a progress indicator (looks like a colored pinwheel), you may have an incompatible login item.
To find out if you have an incompatible login item:
Shut down your computer and wait 30 seconds.
Press the power button.
Immediately after you hear the startup tone, press and hold the Shift key.
Release the Shift key when you see the gray Apple and progress indicator.
Choose Apple menu > System Preferences.
Click Accounts, then click Login Items.
Make a list of the login items--you'll need to remember them later.
Select all of the login items and click Remove.
Choose Apple menu > Restart.
If this solves the problem, open Accounts preferences again and add the login items one at a time, restarting your computer after adding each one, until the symptom occurs again. (You can start up your computer normally when you're adding the login items.) When you've found the incompatible login item, use the procedure above to remove just the problem item.
这个答案有帮助吗?
得分 3
添加一条评论
YES -- this could be a hardware issue with the Graphics Card / Logic Board.
Since it starts in "safe" mode, and if you look at the files in System/Library/Extensions after a safe boot you will notice that they are not the same as those in a "normal boot'... there could be a corrupt or unneeded driver in the normal set that you could delete or replace. I have had success doing that with a troublesome machine in the past.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
2条评论:
I've noticed that there are lots extensions files. How shall I be able to see the files in a normal boot?
完成的
You need access to an other mac you target boot your machine, then navigate to the normal startup set from the second machine.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,328
