跳转到主内容
加入维修社区 - 创建账户
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
Steam deck dropped Not charging
Steam deck got dropped on the floor now it’s not charging. How can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi! Does it still turn on when connected to the power? Will it also turn on, on the battery it self? Could be a faulty battery (not very likely), faulty USB port or motherboard related (which is most likely).
完成的
Hi Richard, could you answer Koppie007's comment as he is trying to help you
完成的
The problem is that the power cord does not stay connected to the steam deck unit - whatever it plugs into must’ve got jostled or broken and even if you hold the power cord in place, the steam deck is not charging. I just called UbreakIfix, they charge $60 for a diagnostic and said it could be as high as $200 if they have to do any soldering.
完成的
Hi!
Okay, in this case it DOES sound like a broken USB-C connector. Soldering is required to get this fixed…
Do you have any soldering experience? If not, I would let someone do the repair.
Sorry for the bad news :(
完成的
I took it to one of those uBreakiFix stores. They said that the charging port had been pushed in and will need replaced. The cost of repairs is between $60 and $200.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
Yeah, then they do need to replace the USB-C port. The port is soldered on the board, so if you have no soldering experience, I would let them do it.
60-200$ gap is big. So I would ask them how expensive it precisely is.
Please let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Richard Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 99
