跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Controllers/joycons disconnecting, not synching
Im having intermittent connectivity with controllers (joycon, pro controller, 3rd party) on my switch, I have verified that the antennas, both BT and Wifi are firmly corrected and event tested continuity from the antenna board to the switch MB, WIFI seems to work OK although I dont have a real way to test for continuous wifi connection. Issue persist either docked or undocked.
Most of the time the controllers wont connect, and when they do, its only for a short while, and usually just after restarting and only after connecting to a wifi network.
Wireless controller IC seems fine and no damaged capacitors/resistors nearby, also checked capacitors near APU and they are OK.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Are you sure that the bluetooth controller is fine?
As how you are describing it I would say that there is something going on with the antenna’s..
I would replace some parts and see how that goes. New antenna’s are not that expensive and easy to replace and test.
If that’s not it, then it must be motherboard related.
I think there is not much left to try… sorry.
这个答案有帮助吗?
得分 0
2条评论:
Yes, tested controllers on a different switch, waiting for a replacement BT antenna, just was hoping to get pointers of any possible SMT components that could cause the issue, appreciate the comment
完成的
Alright, will check the antenna’s with new ones first and see how that goes. If that fails it’s probably the bluetooth IC on the board..
完成的
添加一条评论
添加你的答案
Zeroth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 26
过去 30 天: 26
总计 26
