跳转到主内容
加入维修社区 - 创建账户
Husky H2G3TK 空气压缩机是一款便携式有线电动空气压缩机,配备 2.0 马力电机、2.6 加仑储气罐,最大压力为 135 PSI。本页面提供了这款重 30 磅的紧凑型压缩机的详细信息和维修指南,它适用于轻型任务并配有控制调节器。
Compressor doesn't start?
Give the replacement motor part number which isn't listed. But the motor is shown. Thanks 👍 😊
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
On the diagram this
would be a pressure switch. That would be the second thing to check after the on/off switch. You should be able to see resistance on the 2 terminals of the power plug with the on/off switch on. If not, short out the pressure switch and see if resistance shows - it should be relatively low, 1-5Ω.
If there is no reading then you might have a bad motor. Try reading directly on the motor leads.
BAsically.
Troubleshooting the Motor:
If the motor doesn't start, common checks include:
  • Confirming proper power supply (breaker/fuse).
  • Checking for proper extension cord use (avoiding overly long or thin cords).
  • Letting the motor cool down if the thermal overload has tripped.
  • Issues with the pressure switch or internal components like reed valves or brushes if it runs but doesn't build pressure.
这个答案有帮助吗?
得分 0
1条评论:
Could also be a bad capacitor....
由完成的 分享
添加一条评论
添加你的答案
SON'S 360 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 51
总计 371
