跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
retrieving data from a ps3 hard drive
how do i retrieve the data from a ps3 slim hard drive as i have movies videos and other personal files and folders on the drive but unable to retrieve them so how do i do this as i want the drive contents off if a full memory wipe is to be performed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi!
You cannot connect it to your PC and read the data from the HDD. This is because the data is encrypted with a unique key.
If the PS3 is still stock, the options are very limited and the chance is small that you can transfer it to your PC or NAS (it only can play from the NAS).
What kind of video's do you mean? Home videos? Downloaded movies from the PS Store? If the PS3 is still working, you can try to transfer them with a USB.
Plug the USB drive into the PS3 and go to Video > Highlight the video file > Press triangle and go to copy, copy it to your USB drive.
Be aware: Only FAT32 formatted USB drives will work, so the file size is limited to 4GB.
And what do you mean with personal files..?
There are not that many options left, I'm afraid.
这个答案有帮助吗?
得分 1
4条评论:
does not matter what type of files they are just need to retrieve them
完成的
The only thing you can try is to plug in a formatted FAT32 USB drive. Go to the files and movies, press triangle and search for the copy option. Copy it to your USB drive. That is the only way if your PS3 is stock.
完成的
@dan0 I am unable to access the ps home as I utilised the drive using windows 11
完成的
If the drive is utilized it’s impossible to retrieve the data… sorry for thr bad news :(
完成的
添加一条评论
Take it apart and connect to a PC using a SATA/SAS to USB cable.
Retrieve the files using your file explorer and then reconnect to your PS3
这个答案有帮助吗?
得分 0
4条评论:
I don't think it works that way. The PS3 drive is encrypted with a unique key. You cannot just read the data on a computer.
完成的
I already tried that and nothing so that is bull
完成的
I completely forgot about that thanks guys!
Use this: https://github.com/jhonathanc/PS3-HDD-Re... make sure to follow the instructions. Good luck!
also use https://www.psx-place.com/threads/dumpin... for the root key
完成的
No problem at all! We are trying to help in any way :).
完成的
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 235
