跳转到主内容
加入维修社区 - 创建账户
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
NAND Upgrade on iPhone 12 Pro Max
Hi everyone,
I’m working on a iPhone 12 Pro Max board and need to upgrade NAND storage.
The question is:
When replacing the NAND on this model, is it mandatory to use a software tool like U3Tools (or similar) to reprogram/initialize the new chip?
If so, what is the correct procedure after installing the new NAND?
Should I read before the data on the original NAND chip and then paste it on the new one after?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Most shops use a mill to grind down the old NAND chip as it's safer and less trauma to the logic board. As you can see in this YouTube vid iPhone 12 Pro upgrade storage capacity SSD Nand from 128GB to 512GB
And yes you do need to setup the NAND chip using Apples DFU method or U3Tools. If the persons data is important you do need to make a back up. As it sounds like you've never done this I would recommend finding someone who has done a few as it's not that easy! Or at least try out on your own phone you don't care about as there's a strong chance the first one will fail.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Giuseppe Greco 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 63
总计 211
