跳转到主内容
加入维修社区 - 创建账户
Mac mini 是最初发布于2005年1月22日的小型桌面电脑。目前,它是 Mac 桌面电脑产品线四款产品之一,主要作为一体台式机 iMac 的替代产品。
Mac mini 2010 won't boot
My Mac mini 2010 (a1347 sn C07CVGNDD6H) will not boot. On power up, the mini will sound the apple chime but the everything appears to stop at the grey screen. No apple logo, question marks etc... Just a grey screen.
The power light on the front of the unit is luminated as it should.
I thought perhaps the he'd was faulty, so I replaced with an ssd (thought I'd upgrade anyway) but the same problem remains. I have also tried to boot for the DVD - pressing the 'c' button on startup. The DVD appears to run and then ejects after a min or two. Any ideas?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try disconnecting the hard drive and then booting from your DVD. If this works, replace the hard drive.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the suggestion. The Mac mini doesn't seem to recognize the USB keyboard - as a result the keyboard commands are useless, and i can't get the mini to boot from the DVD.
Is there any other way I can't get the mini to boot via the DVD.
完成的
添加一条评论
Which disc are you trying to boot from? The Mac Mini 2010 will only boot from a disc that is OS X 10.6.4 Snow Leopard or later?
If so then try the steps below.
Reset PRAM Hold Apple+Option+P+R keys at startup
Reset SMC. Shut down the computer. Unplug the computer's power cord. Wait fifteen seconds. Attach the computer's power cord. Wait five seconds, then press the power button to turn on the computer.
Update
Is that the OEM disc you received with the machine?
If not that is why it wont boot.
You could put the Mini hard drive in another machine that can boot to 10.6.3 install the OS and update it and put it back in the mini and it will work (If the OS version is the issue.)
Update
I just saw your response above regarding USB. Can you not get to startup manager?
Hold Option key at startup and you should see the mouse pointer on the screen if no bootable drives are present.
这个答案有帮助吗?
得分 0
2条评论:
The disc is OS 10.6.3
完成的
I only have the Mac OS X 10.6.3 and the Applications Disc. There appears to be no power to the keyboard, and so I cannot initiate startup manager. I've plugged in the LAN cable and checked the network, via my iPad, to see if the ip address shows up, but there is nothing showing. I don't have access to a second Mac or a PC.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 7,779
