跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why are my apps not loading?
tap apps then flash to game then goes back to the home screen
the same thing is happening to me but i have the 4th generation
help anybody?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Check your capacity... You may be near the limit, remove the last installed app, clean up your phone and get rid of things you don't use. Double click home and all the last used apps/ background apps open. Close them down
这个答案有帮助吗?
得分 3
添加一条评论
If Pollytintop's answer didn't fix your problem, press the home button first and sleep button next and keep pressing it for exactly 8 seconds. Release pressing and leave it for next 15 seconds. Now press sleep button again to power on.
See if it fixes your issue. If not, connect it to iTunes, Backup and then Restore it. It should work. Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyler Knutson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 402
