跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
Non Functioning USB's
Hello,
I got in a PS5 with EDM-010 motherboard.
The USB's are in pristine condition but, not a single one connects to the motherboard when console posts to White Light.
That's right the console will turn on and post to White Light. This is supposed to be where you connect a Controller and press the PS5 button to connect controller and start the system to next point.
When I did turn the console on it kept saying and posting that to many USB devices are connected.
Anybody have an idea?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Hopefully this answer can help you too: My front USB port not reading any of my DualSense
Did you tried with a USB-C to USB-A cable? Or a USB-C to USB-C cable? I would try both, just to test.
Otherwise, replacing the USB ports would be the first test. It could be the USB controller, but this requires soldering…
Please let us know how it goes!
这个答案有帮助吗?
得分 1
2条评论:
Koppie007
Yes I’ve tried different combinations of cables and also different dual sense controllers.
The cables and controllers work on other PS5 consoles.
Still stumped.
完成的
Hmm.. yes, you also tried the USB ports on the back, right? If the same issue occurs there, I think it’s the USB controller that need to be replaced :(… you can try using a different USB board and see how that works out! But I think this is not it..
完成的
添加一条评论
添加你的答案
Marty Robinson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 41
