跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
battery not detected ,fan at 100% spin,lagging
Hi. ok..i try to put new paste on logic board.but... obviously mine mistake what happen.. i disconeccted all connectors but didn't mine battery and in middle of process MB turn on..and i didn't know how to turn it of untill 30 sec he do it.after i assembly again, mine battery won't work and appl os can't see it in system report.also, fans are at 100% and all is lagging.tryed to reset smc but no help.any help would apreciate..thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This looks like the battery board data cable is not properly connected into the ZIF connections. Review Steps 9 to 14 in this guide 2019年16寸MacBook Pro 电池更换 take note on the way the ZIF connectors work and make sure the cable is not damaged here's the replacement MacBook Pro 16" BMU Flex Cable
这个答案有帮助吗?
得分 2
9条评论:
ok,will check the cable and order.new one.But can u explain me is there a chance that something else is broken,sine MB suddenly by himself turn on while i was doing that?If i remember after the last one of the right side cables disconnected ,he turned on and,since i didn't know how to turn it off,he did it by himself 30 sec after,and in that stage fan eas spinning fully if I am remembering correctly
完成的
i mean, can battery in that short period of time be broken somehow? it was 75% of battery capacity,and 240 cycle
完成的
@icyeye - The battery is not the focus here as the communication between the battery to the logic board is not present (that cable). Your screenshot shows the battery is not talking to the logic board.
While you should have disconnected the battery before taking things apart. So you could still have issues but we need to solve the obvious issue first.
Start by checking the ZIF connectors if the latches are correctly set.
完成的
ok.i edited post and add the picture. maybe u can see if there is something wierd. i only detached the right side of the cable...
完成的
@icyeye The cable is not fully into the ZIF connector, read again the guide step mentioned above and take it slow and gentle. The cable needs to be fully inserted so none of the gold traces are visible. Gently lift up the latech, thread in the cable, lock the latch.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
icy eye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 59
