跳转到主内容
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Controller won’t power on or charge
To give yall some background context: I tried to solder on some brand new TMR joysticks onto my PS4 JDM-055 controller. After soldering them, it worked for a little bit. I wanted to resolder one of the sticks and I think I shorted the controller. As you assumed it no longer turns on. I don’t know what to do from here on out cause I don’t know where a certified technician in my area would be and I just want my controller to work again.
If any of yall could help that would be much appreciated
Back image
Front image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks for the pictures! Soldering looks fine.. I would check the motherboard for shorts! Otherwise a replacement is required..
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Brody!
Can you share a picture with us regarding the solder work? It's possible that a trace is damaged or the motherboard had too much heat and thus something died on there.
Guide for the pictures: Adding images to an existing question - iFixit Repair Guide
Please check all the cables, solder pads and traces. If nothing is visible at first, then I would replace the motherboard OR you can check for shorts.
So, this should be the part you need: DualShock 4 Controller Motherboard (JDM-055)
Please let us know how it goes!
Main circuit board assembly for the seventh generation (JDM-055) PS4 DualShock 4 Controller.图片
产品
$34.99
这个答案有帮助吗?
得分 1
2条评论:
Hello! Is the controller motherboard authentic?
完成的
Hi! No, you can just swap motherboards! But you need the correct model as the original motherboard, otherwise it won't fit or can give issues.
完成的
添加一条评论
Well checkout the following video it might help you in fixing the issue: https://www.youtube.com/watch?v=KC9GeYyM...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brody Girton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 47
