LT gets pressed and slowly releasing
My coworker tried installing an ExtremeRate clicky trigger kit after I did mine, but he ran into issues and asked me to fix it. Right now, the controller only works when the trigger is adjusted to the shortest throw, where the clicky switch actually engages, but it's really slow to release. It looks like he may have overheated the joystick area while soldering, though I'm not certain if that would affect the triggers. I removed all his solder, replaced the damaged ribbon cable, and reinstalled a new clicky kit, but the issue remains.
Update (11/03/25)
So I circle where you solder on the right side you solder to the right side of that little diod guy idk what ya call it and the one on the left side you solder to the bottom what he ended up doing on the left side diod guy was fill both sides together he did also get the joystick pretty hot and melted it some
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
10条评论:
Hi!
Can you share any pictures with us regarding the solder work and the triggers?
在已经存在的问题里加入图片
Thank you!
完成的
Yea I can when I get off work today
完成的
That is fine! Thank you!
完成的
Hmm, the picture is somewhat blurry! I cannot zoom in.
Please check the traces, are they fine? Did you tried replacing the sticks again?
Thanks!
完成的
The sticks do still work but the left trigger is out dose the left trigger have anything to do with the trigger?
完成的
显示更多的5条评论
添加一条评论
