跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
No hdd in disk utility on cd boot only optical drive.
I assume I need to replace the hdd however not sure if the one you sell is compatible. The repair guide has a related part to buy but when I click on it is says it's not compatible with the 21.5" intel imac. Can anyone clarify?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Apple has installed Proprietary hard drives in this machine with special firmware with seven lead sensors. Ordinary hard drives will not work. You're going to have to get it directly from Apple.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Aidan Gould 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 488
