跳转到主内容
加入维修社区 - 创建账户
Bosch 11247 是一款有线电动电锤,专为在混凝土、石材和砖石上钻孔而设计。它提供双模式操作,每分钟可进行 400 次旋转和 3,000 次冲击。本页面提供了这款长 17-1/4 英寸、重 13.6 磅的钻机及其使用 10mm 柄径或 1/2 英寸普通钻头的更多信息和维修指南。
It won't hammer
It won't hammer. Bits & chucks are ok
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello @indymark
I am not familiar with the specific model but is it one that has a switch to turn the hammering on and off? If that's the case, the switch clicks in just fine? Some of these kinds of switches I came across are round and need to be turned, others are rectangular and need to be pushed back and forth. Once I had a similar problem on a drill, the lever that selects the torque, it looked like it was pushed in but it only traveled 90% of the way and didn't fully engage because of some dirt that got stuck in the path where it slides.
Worth a look, and maybe an air compressed blow if you have it! Before you start looking into more serious causes that is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Indy Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 297
