跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
joycon gets stuck in rail after reassembly
my left joycon, after playing handheld for a bit or leaving the joycon docked for a few hours gets stuck, and i need to wiggle it to make it unstuck. my lower screw on the shell, the one closest to the rail, is stripped, and the rail is a tint bit loose, as when i exert pressure on it it moves like 0.2 mm. i didnt touch the screw that joins the rail to the shell. is it safe to play this way. i am really scared i might ruin the switch or the joycon long term, making me unable to play handheld. any help would be greatly appreciated, either telling me if the problem is only the screw, or about the technicalities of keeping it this way. the stripped screw is really pushed deep and i dont know if i can screw it more. i really need an answer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
If that's the case, you could take a power drill and a very thin drill bit and try to drill holes on both sides of the screw so that you could turn it with a flat head screwdriver or maybe a spanner. Then you could get the screw out and figure out why it's getting stuck.
完成的
ill see if i have that probably tomorrow, since ill get home quite late today. i will be giving updates thank you very much!
完成的
添加一条评论
1个答案
已选择的解决方案
First of all, I would suggest that if you have a charging station for those joy-cons, use it instead of the console and play in handheld with them detached. This would at least assure that you could continue playing handheld without worry of them (the joy-cons) becoming permanently stuck. Secondly, what sort of procedure were you doing on these joy-cons? And thirdly, is the stripped screw open enough to reach with needle nose pliers? If not, you might need to break off a chunk of the plastic shell to get to it with some pliers (don't do this unless you're desperate!)
这个答案有帮助吗?
得分 1
1条评论:
Gabriel Silva: @fixerofstuff thank you so much for your answer. i changed the joystick and trhe sl/sr flexible cable. and it is really deep. it looks as deep as the other ones. however i feel like because its stripped it doesnt hold on as well. once again thank you so much!
完成的
添加一条评论
添加你的答案
Gabriel Silva 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 72
