跳转到主内容
The TI-Nspire CX II handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery. Released in 2019.
My Battery wont charge when I plug it in.
It turns on when i plug it in and i know the battery works; I tested it in another calculator. I even changed the battery. It works fine when it is plugged in though.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Have you tried a different battery in your calculator?
完成的
@thelastmill Please read more carefully. the OP stated clearly that they changed the battery.
完成的
Yeah I misread that.
完成的
@theLastMellenial I accedentaly used the wrong battery twice so you helped and now I have the same problem
完成的
添加一条评论
1个答案
If a different battery and different charger don't resolve the problem then there's an issue with the charging circuit. Unfortunately TI made the Nspire CX family extremely difficult to disassemble and there's nothing relevant to replace on the inside anyways.
You can try pressing and holding the reset button on the back of the calculator for at least two seconds since it's an easy troubleshooting step to try but I don't really expect it to fix your issue.
I'd the calculator is less than a year old then use your warranty to get a new one. Otherwise you may need to keep a battery bank plugged into the calculator from now on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rider Breneamn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 98
