跳转到主内容
加入维修社区 - 创建账户
Sometimes it starts Charging...
Having a problem with this machine. It sometimes starts charging up but most of the times not. Most if the times laptop doesn't even detect the charger . otherwise laptop is working fine no other problem. i opened up the laptop, removed the logic board and saw a very liitle liquid damage near where charging socket connect with logic board. After cleaning it not charging up now means no light in charger . i already changed the charging connecter also.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Anyone upload the picture of that area of working laptop?
完成的
添加一条评论
2个答案
已选择的解决方案
Change the AC adapter and let us know what you get.
这个答案有帮助吗?
得分 4
10条评论:
i changed 3 chargers and tried with 85 watt also. same . i m uploading the pictures of damage before and after cleaning.
完成的
That looks like more than a little water damage to me. My experience with liquid damaged boards holds very little hope. Once these things have shorted out there's just not much hope of ever doing with it.
完成的
Now when i plug the charger in it just give a green light for 2 sec then nothing .
完成的
Try replacing the DC-IN (Magsafe board) it's cheap and about the only thing you can do at this point.
完成的
i already done this also.
完成的
显示更多的5条评论
添加一条评论
I had a similar problem with a water damaged 15" mid 2009 Unibody Pro.
It would not charge, not recognize the connected power adapter everytime, and would sometimes display a dim green light.
I changed the battery and it still did not remedy the problem
I eventually disconnected the led battery life indicator ribbon from the logic board and it started charging immediately!!
Once I removed the led indicator, it was obvious that it had shorted out due to water damage.
So before trying a new logic board, I would definitely try this!!
这个答案有帮助吗?
得分 0
2条评论:
First clean the logic board properly. then leave it for few hours then try to power up
完成的
Noted with thanks
完成的
添加一条评论
添加你的答案
SIMRAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,942
