跳转到主内容
加入维修社区 - 创建账户
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
Side buttons and screen will not function after screen replacement
Title says it. None of the side buttons do anything anymore. Also put new screen on it, phone powers up but not the screen. I’ve done the basic troubleshooting checking the connectors and ensure clean. Carefully switched the sensor stuff over but can’t figure out why the screen won’t come on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Did you try to connect it to your computer? If it shows up in iTunes then restore it to see if that solves the issue. If there's data in it then back it up first.
完成的
Did the side buttons function at all before replacing the screen?
完成的
No I haven’t tried connecting to pc. Could it simply be just a software issue? Potentially of course. Is that what you’re sayin?
-no the side buttons quit before the screen swap.
-oh I made sure I was careful. I started fixing my phones ooooooh hmmm right around iPhone 8 era. This is the first time I’ve had one not work though. So 🤷‍♂️
完成的
Tried connecting to pc and found softwares like reiboot. But they only work and force recovery mode IF you can establish usb connection. Which since phone is in initial power on state, you HAVE to punch in the screen passcode to do the initial screen unlock before the usb will work when the screen is locked in the future i guess.
完成的
添加一条评论
1个答案
Maybe you torn down the interface cable or just bad connected it? It's easy to destroy those cables when doing a self-made display replacement. To recover them, you'll need a microscope.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
busapower07 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 99
