跳转到主内容
加入维修社区 - 创建账户
combo drive won't eject disk
replaced drive and have the same problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Can you give us a history so that we've got something to work with?
完成的
添加一条评论
6个答案
已选择的解决方案
I would suspect a bad optical drive ribbon cable. The cable on this iBook G4 model is fragile. Remove the optical drive and check the ribbon cable silver contacts (the side that connects inside the logic board socket). Check if the contacts are all well aligned and not damaged. If so, replace the ribbon cable.
这个答案有帮助吗?
得分 1
1条评论:
+ Ralph
完成的
添加一条评论
最有帮助的答案
Have you tried shutting off the machine, then booting while holding the trackpad button down? That should tell the machine to force the disc out.
这个答案有帮助吗?
得分 1
添加一条评论
I've tried rebooting with the trackpack held and have reset the PMU.
这个答案有帮助吗?
得分 0
1条评论:
Is this the exact same problem you had before you replaced the drive? Where did the new drive come from?
完成的
添加一条评论
same problem as I had before replacing with iFixit drive.
这个答案有帮助吗?
得分 0
2条评论:
Do you mind telling us what that problem was? It seems it might not have been the drive.
完成的
Is the disk catching at the case? Maybe its a simple misalignment.
完成的
添加一条评论
The disc won't eject from the drive
这个答案有帮助吗?
得分 0
1条评论:
has nothing to do with the hard drive. I don't think I can help you.
完成的
添加一条评论
See these similar answers.
Good Luck,
N
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wmcgarry2000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 2,035
