跳转到主内容
加入维修社区 - 创建账户
HP 600 系列笔记本电脑的维修信息。
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
完成的
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
完成的
@anwar29099
What is the full model number of the laptop that doesn't charge?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anwar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 152
