跳转到主内容
加入维修社区 - 创建账户
采用了更小的散热片和用户可手动拧紧的底座螺丝。
Why is my ps5 not turning on
My ps5 will not turn on. I tried different outlets and different power cords and nothing is working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
does it beep
这个答案有帮助吗?
得分 0
5条评论:
If it doesn't, it is possible that the power supply is dead and need to be replaced. See guide: PlayStation 5 Power Supply Replacement. But important to know is, if it beeps and if it's showing any light!
完成的
I have a similar issue with my console, but it beeps once, the blue light flashes and doesn’t turn on. What do you think is causing this?
完成的
Probably the APU… you can try a reflow first and see how that goes. Otherwise you might want to reball it or replace the chip. This is really difficult and requires some serious soldering skills and expensive equipment. Better to replace the motherboard if you don’t have experience with this or go to a local repair shop for the repair!
完成的
@dan0 its very unlikely its the apu better suggesting uart instead of going straight for an apu reflow as it could be anything like a short, bad south bridge or wifi ic
完成的
Hi Daniel! The comment was meant for Nitter, but you are right! It could be the south bridge or a short, or something else on the motherboard. Sorry for the misunderstanding.
完成的
添加一条评论
添加你的答案
Baba Yaga 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 220
