跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
No Backlight
i need help on how to get back the light on my iphone it is very dark and i know it is the backlight problem but i need help to know how to fix it im scared to open it apart and miss the whole thing up!!!! please help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi Layla. It seems you might need to replace the Display Assembly. Feel free to use our guide and let us know if you need any help. Best of luck!
Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone.图片
产品
iPhone 3G Display Assembly
$59.99
这个答案有帮助吗?
得分 2
1条评论:
Although replacing the entire display assembly is undoubtedly the easiest solution, particularly for the less tech inclined, it may not actually fix the issue. Replacing the components responsible for this function is likely to be what's required. But, it does entail desoldering and soldering of 1 or both components on the mother board. See this source, it provides a great zoom pix of component location http://www.amazon.com/CyberDoc-LLC-iPhon.... You can buy both components very reasonably or separately from a NYC vendor.
完成的
添加一条评论
添加你的答案
layla ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 987
