跳转到主内容
2015款 Nintendo 3DS XL,也被称为新 Nintendo 3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
3DS not charging properly
Hi, this device will not charge properly, when plugged in with a brand new battery, the device will show the orange charging indicator, after unplugging the charger the orange charging indicator stays on. The device will NOT turn on. I have already tried 2 different chargers, the battery is brand new.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Did you had the same with original battery? If not, it could be that the replacement battery is faulty.
I would try a new one first and see how that goes.
If the same issue is happening again, then you might want to check the motherboard.. Also please check the fuses which are labeled with "F" on the motherboard with a multimeter.
If you have any questions, please let me know!
这个答案有帮助吗?
得分 1
2条评论:
Hey, the problem seems to have worsened now, I haven’t checked it with a multimeter yet cuz i didn’t but it yet, but when plugged in, the orange charging light shows up for 5 seconds then goes away. I’ve tried two different chargers and two batteries, any help would be appreciated.
完成的
Okay, when you tried multiple batteries and the same issue ocur, it's motherboard related. I would check the fuses first. How are the battery pins?
Thanks!
完成的
添加一条评论
添加你的答案
JoeGaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 57
