跳转到主内容
加入维修社区 - 创建账户
Dell OptiPlex 780 Small Form Factor (SFF) 于 2009 年发布,是 Dell OptiPlex 780 系列中的一款迷你台式机。其型号为 DCCY1F。
My PC won't boot or take input
Hi.
So recently, let's say during the past month, my PC sometimes would just go dead. I generally hibernate it bc I don't want to wait for it to startup and have to reopen all my apps. But sometimes when I press the power button, it's completely dead. So I tried switching power cables which worked for a while, but soon even that didn't work. I ended up doing a clean reset on one of the few miracle moments it did start (Win11 Pro). And for a couple weeks it worked perfectly, until it didn't. It either went dead or booted onto a blue screen that said diagnose device (paraphrasing here, you get it). Now, everytime I start it, it beeps once and opens onto a text screen saying 'date and time inaccurate'. There are options to boot or go to startup settings and what, but it's not accepting any input from my keyboard. Please help me someone.
Thank you in advance, and sorry for the essay but I felt I needed to be detailed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
There is a CR2032 battery that needs replacement inside the computer. Easy to access.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @faiyazdadamia
based on my experience, i believed the power supply is having some issues, which is probably caused by bad capacitors
https://crawlsbackward.blogspot.com/2016...
another thought on wrong timing and lost of setting in bios is to replace the cr2032 button battery.
这个答案有帮助吗?
得分 0
2条评论:
Thank you so much. I do have a another case with a PSU but do you think it would be possible to switch the motherboard? I know that the motherboard is built per case but I have projects on my PC that I need to work on
完成的
@faiyazdadamia, well you can try, and most impt..... backup important data
完成的
添加一条评论
添加你的答案
Faiyaz Dadamia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 407
