跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
Why are my button inputs registering on the left analogue stick?
I’ve had this problem a while now. When I view the calibration screen, it seems like the left trigger and x button register as a strong right drag on the left stick. It also seems to drag the right stick very slightly off center.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi! What did you tried so far? I would open it up and clean everything inside there with isopropyl alcohol.
If this didn’t worked, then you can try to replace the sticks and see if that works.
If not, it’s most likely the motherboard..
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Fleck 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 62
