Misaligned Firmware Error in Fix It Hub Console (v1.4.0)
Firmware version 1.4.0 is consistently triggering a "misaligned firmware" error in the Fix It Hub Console.
I’ve confirmed that both the Smart Station and the Iron are running firmware version 1.4.0. However, when I downgrade both devices to version 1.3.2, the error disappears.
I believe this may be a false error. When I check the firmware directly from the Smart Station’s menu, it correctly reports that both the Smart Station and the Iron are on version 1.4.0.
However, when I click on the error message in the Fix It Hub Console, it shows the Iron firmware as blank, while the Hub firmware still shows 1.4.0.
I’ve also tested this on a second computer to rule out a browser issue, and the behavior is the same.
Any thoughts on what might be causing this?
4条评论
@deano2064, Sorry this is happening. I'm checking in with the team and will have an update for you soon.
由 Kris Rodriguez 完成的
I'm also facing this issue with my FixHub station and soldering iron in the web console. I infer this is a false positive as well, since I observed the same result in the FixHub web console (though I didn't test if downgrading to firmware version 1.3.2 makes this bug go away).
Here's a screenshot from the web console: https://ibb.co/rPB6GQQ
Anyways, this is a friendly reminder that the FixHub soldering iron has its own firmware that may be updated through the FixHub web console: https://www.ifixit.com/fixhub/console
由 Tai Lam 完成的
I've forward your issue to the iFixit folks, hang tight!
由 DanJ 完成的
100% the same here...
Soldering works just fine, but the false positive due to missing firmware number of the soldering iron can be irritating.
由 BenZ78 完成的
