跳转到主内容
加入维修社区 - 创建账户
Why my mower won't start
No mater how much you pull on the rip cord . It will not start
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
gas motors require spark, fuel and air to run.
For a lawn mower, that is the order to search for the problem.
You can test the spark by removing the spark plug, connect the lead, and securely connecting the case to the engine metal.
If no spark, disconnect the plug, and test the lead using a long screwdriver with a plastic handle. Better if 2 ppl do this. If you have spark, replace the plug. If you don't, it may be beyond your skill to fix.
If you have spark, then it is likely the carburetor need cleaning or replacement.
That would be evident if there was no fuel smell after a number of pulls.
A blocked air filter may allow it to start momentarily.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicole Mayberry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 206
