跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,新 Nintendo 2DS XL 是 Nintendo 2DS 掌上游戏机的迭代机型。
How do I replace my speaker with a broken wire?
When i was replacing my circle pad i accidentally snapped a wire that connected a speaker to the device. Is it possible to replace it? I was able to take the speaker out but i cant find anything that looks like it that isn't a switch speaker. Should i just order a switch speaker? Are they the same size?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Yes you actually can! They are the same size and will fit. There are plenty of tests done and it does fit and work.
Unfortunately, the cable came out the connector completely… so the speaker need to be replaced completely. The speakers aren’t that expensive, so you should be good to go. The connector on the motherboard, is still fine, right? If yes, then just replace the speaker!
这个答案有帮助吗?
得分 2
2条评论:
Thank you!!!
完成的
My pleasure! Good luck with the repair!
完成的
添加一条评论
添加你的答案
Macaroni and Trees 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 61
总计 343
