跳转到主内容
加入维修社区 - 创建账户
2015 年推出的惠普 HP Officejet 单功能打印机。
Printer won't pick up paper
That's basically it. It makes all the whirring noises but it does not collect paper from tray (and thus, says there's no paper). I've tried a single sheet, I've tried loading the tray full, but nothing seems to work. And I can't really see if the little roller-thingies move or not.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have one of these that is also not picking up paper. The pickup rollers are not being driven. The arm with the rollers drops down but the rollers don't turn. I'm having a bear of a time trying to find a repair manual for disassembly.
由完成的
添加一条评论
2个答案
最有帮助的答案
@dalew7311 I ran into the same problem with my OfficeJet 6700 and finally found a video online that showed the problem. After fixing it, I made an iFixit guide to that repair that you might want to take a look at to see if your printer is doing the same thing.
HP Officejet 6700 Paper Feed Fix - iFixit Repair Guide
Basically, there's a gear that drives the pickup rollers and it either slides out of position or gets stripped inside so the shaft that drives it no longer turns the gear. In the former case, all you have to do is slide it back into position, but if it's stripped inside you'll need to use some epoxy to resecure it to the shaft.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for that. I had another MFP this summer that did the same thing which is why I recognized the problem with the 6230 that I'm working on now. Removing that top portion of the paper tray might be the key to fixing this one. It doesn't come out easy and I haven't wanted to force it. Watching your video makes it seem possible. On this 6230 the whole bottom tray does come out so I can just flip it over and not need the mirror. I didn't use epoxy on the one this summer, just super glue and as far as I know it's still working. I'll report back on how this goes. Thanks.
由完成的
添加一条评论
Wwas there a paper jam that you had to remove before this? Check from the from of the printer for torn paper in the paper path? Sometimes especially with modern printers that are basically made to be disposable ( unless you buy an business class printer) it’s had to see the cause without taking them apart! Check the paper path is clear! Try feeding some stiff card through it…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ma T 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 41
总计 239
